Tranzor wrote:How hot was it? I've found the best 1/4 mile times are usually had in the mid 60s or so for temp. Too cold, no traction, too hot, there's too much heat soak so the car slows down.
I'll be hitting the track up soon to get a gauge on where this car is at stock before I start delving into the few mods there are for these cars.
Our DA here is usually pretty good... the track is a little elevated (like 400' or so above sea level), but usually DA only crests 2000' in the middle of summer when it's hot... otherwise, this time of year, it stays below 1000' DA.
It was 86 and 45% humidity - thats a lot of humidity for us down here in the desert. Firebird is known to be more humid because of the lake right next to the racetrack. Definitely hotter and more humid from the last 2 times to the track.
And heatsoak is terrible on these cars. The intake manifold was so farkin hot I just touched it for less than a second and it near gave me a 2nd degree burn. We either need a Titan Plastic intake manifold or an intake manifold phoenolic spacer to combat heat transfer to the incoming airstream.
I honestly will be working to get the ECU tuned so to add forced induction before I try and get anything like that
