ks13 wrote:where will you be plumbing the oil feed to the block?
This is just a first stage of testing sort of thing right now, I have to mount up the pump to the block still and get my new pan finished up before anything else dry sump gets worked on. But the plan for now is to integrate the feed into an adapter that also redirects the filter to a remote location. I have seen a couple of ford 2.3t's with this sort of setup.
I am having the machinist leave all the plugs and **** out of the block until tuesday so I can get up there and play around with this idea and some others. I have already "deactivated" my stock oil pump; the housing is actually still going to serve as an oil passage for the motor, it just won't have any pieces turning or a sump attached to it. That leaves us with another good place to play with getting the oil feed right. The best thing about it all is that I can now push as much oil pressure into the motor as I want, and the motor really needs it for the head so long as i can get it to evacuate just as well.
We have been doing some projections based on charts of 350 sbc's with this same pump to try and get an idea of the vacuum I could possibly pull on the block with just two pan pickups, and it may be able to keep the bottom end at neutral pressure at least. If I can get a manifold or something that lets me get more than two scavenge lines on there, I will be set.
I have proven through some math that the stock setup ca18det can't even flow the max amount of oil this pump will pump at max pressure without staying nearly too cool to run, with ten quarts of oil in the system and my oil cooler. So, if those two extra scavenge lines become reality, they will be going to the back of the head, one on the exhaust and one on the intake side. If not, I will set up the drain back mod to the pan right beside one of my main scavenges, and that will at least pull more fluid off the top during acceleration, witch should eliminate most of the oil escaping the head out the breathers.
