J-Owner »
https://forums.nicoclub.com/j-owner-u3840.html
Tue Feb 19, 2008 5:14 am
I have an '05 coupe and I just had my oil change at 35,503 and I have 8MM left on the pads on the front and 4MM left on the pads on the back. My back pads are needing replaced soon. They lasted me 3 years and the pads on the front are still the original pads.
You must really ride your brakes
The dealer quoted me $250 for rear pads including resurfacing the rotors. I have another place in Plano that I use when the dealer is too high and they quoted me $170. I think $300 is high unless you need rotors and then for pads and rotors that is probably about right to $100 cheaper than other places.
Using someone other than the dealer DOES NOT void your warranty. Anyone who tells you otherwise is a liar. Just be sure you keep your receipt as prrof the work was done if you are a fanatic about keeping a maintenance log like I am.
Hope my $0.02 helps.
