I lurked here for a few days but didn't see what I was looking for.
My dad and I just got ourselves a sand car that happens to have a sweet VG30ET in it. It runs pretty good, boost is set around 10-12psi from what the gauge is telling me and it pulls like a freight train through all 4 of the VW transaxle's gears. The whole car weighs roughly 900Lbs, so you guys can imagine what a rocket this thing could potentially be, IF it was running right.
The problems we're having: It has a high idle on initial start from cold, around 2k. After you shut it down, restart it and its warmed up, the idle lowers to around 1,200 RPM. After this, the engine will run decent until you get into the throttle and then let off- it dies. Seems like a fuel starvation issue, maybe, because you can keep blipping the throttle to keep it firing until eventually settles back down.
Really, I need a good Nissan guy to check this thing out. I know plenty of Subaru people, but no Nissan specialists. Can anyone in AZ recommend a good mechanic in Valley I can take this thing too? Or are there any good private tuners in AZ I could ask?
Thanks for your help in advance, guys!
Just for SnG's, here is the car:
And a link to a short video that shows the problem:
