Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Sat Oct 24, 2009 9:28 am
what size tire was stock on your truck?
The 4.6s will be suited well for a 30-31" tire. My truck came stock with 235/70/15s and 4.6 gears, and it was a little buzzy at 75mph on the hwy, but had pretty good grunt. When I went to 31s, it was still adequate. More than just the height is considered there - bigger tires are also considerably heavier and will affect seat of the pants feel.
the LSD diffs will typically have an orange sticker on the back that says LSD oil only. Another way to tell is to turn the axle on one side. If the other side turns in the opposite direction, it's an open diff. If it turns in the same direction, it's probably LSD.
