I brought my car to a mechanic to change the water pump and replace the timing belt in 2009. When I went to pick it up the vehicle was not idling properly. This led to being told by the mechanic that I needed a new E.F.I harness, (because it was so brittle and he had broken some of the plugs) I blindly ordered the harness and he installed it. Once again the vehicle was returned to me with a poor idle after the mechanic claimed he did everything right. At this point I was too frustrated to go on with the car and it was parked.
As of today I have revived my Z and am ready to figure out what is causing some problems. I threw in a new battery, some fresh gas, flushed the oil, and she started up fine. It had the same symptoms as when parked:
- erratic idle often leading to the engine dying when cold
- a rough wandering idle when warm
- hesitation/delay between hitting the pedal and revving
- loss of power (what I now know is safety boost)
I started reading. A lot of reading.
I cleaned the throttle bodies out, and adjusted the TPS (0.45 volts), cleaned the air filter/MAF sensor and plug which made a world of difference. The car now has no delay between the pedal and revving and the idle had stabilized, although it is now idling at about 1100 RPM when warm.
The car still tends to hesitate shortly after a cold start up. I verified that my Coolant Temp Sensor connections were clean, and verified that unplugged during a cold start the fan was off, and when plugged it stopped. Once warm the hesitation is gone.
I did an ECU diagnostic and got code 34, which was half expected. I decided that I would try to lower my idle before the code 34 which brought me to this discovery:
Two plugs leading to nowhere. The yellow one just to the right of the middle of the picture and the black one to the left.
This now leads me to believe that there may definitely be some issues in the way this harness has been installed. I am pretty sure I have determined that the yellow plug is for my AAC Valve.(Can someone confirm if aftermarket harnesses use the same plug colors?)
I looked into the IAA unit and discovered this:
It looks like the FICD plug is where the AAC plug should be, and there is no male connector coming from the FICD valve. Does anyone know if there is a way that I can go about getting the male plug and how to install it, or am I looking at buying a whole new IAA unit?
Also as for the black plug, can someone please help me identify this plug? I have been cross referencing between these two sites to identify it,
http://www.300zx-twinturbo.com/cgi-bin/ ... &total=133
http://www.z32photoguide.com/electrical.html
I guess I'll wrap up all my questions here:
- What else can lead to hesitation on a cold start up?
- Based on the pics posted am I right in assuming the yellow plug is for the AAC Valve, the FICD plug is incorrectly on the AAC valve, and the FICD valve is missing a male connector?
- Can I purchase just the male FICD electrical connector, or will a whole IAA unit be needed?
- What is the black connector that is not currently connected to anything?
- Which harness plug should lead to the detonation sensor (wire/plug colors if possible)? I have read that my code 34 could also be a plug mix up, but cannot remember which plugs to check and how to diagnose.
Thanks to anyone who took the time to read any of this rant/welcome/blabbering question post. Any and all replies are greatly appreciated. I'm very open to all suggestions and am hoping I can finally get this thing running the way it deserves to be.
-Ryan.
