New and improved Top Hat Mounts
s13burger
Car: rb20 powered s13
The new and improved mounts even stronger than before. Notice in the bends on the mounts there are no cuts. We have now started to pressure bend all of the mounts. All of the welds are now done by tig, old mount kits were mig welded. If it doesn't have a C cut into it they aren't Core performance mount kits.
IowaRB240SX
Car: 1991 Nissan 240sx
Can I get a close-up of the welds. From the ones you posted they still look like mig. Or stick. The one weld on the top pic has a little tail, which is very uncharacteristic of tig.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
will these be the same price as the older ones?
I was looking to purchase some of the TOP hat mounts and intake manifold for the RB25DET, i am very interested.
I am definetely getting you guy's mounts though.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Good job on the new mounts. The thing I notice the most is the transmission mount. it's sloted for easy install vs the older one.
s13burger
They will still be the same price.
burnin240sx
IowaRB240SX wrote:Can I get a close-up of the welds. From the ones you posted they still look like mig. Or stick. The one weld on the top pic has a little tail, which is very uncharacteristic of tig.
the improved mounts are pressure bent and MIG welded.
There was a mis communication at the shop.
Andrew85cm
Car: 89 240sx with RB20det
Those slots on the transmission mount looks a lot better than mine considering I had to slot mine myself. Good job making a good product great. Hell I am still happy with the old style but this is a much better way of manufacturing.
Nameless EJ6
Car: What the **** do you think.
The mounts look great..
..although I've always thought the metal looked thin. Have you seen McKinney's? (of course you have) They could be used as boat anchors. I believe they MIG theirs.
Couple questions. Are these mounts a 'one kit fits all' type of deal? RB20/25/26? Because I don't see different order options. And have you guys load tested these to determine their average breaking point? Like driving a forklift over a steel toed boot to test it.. same concept. Just curious.
But yea, great idea with the pressure bending and TIG.
Chiba_kun
With the use of the TopHat mount kit (or McKinney) is it still necessary to use the Skyline front crossmember?
Kansei240sx
Nope, Tophats mounts are made for the KA crossmember
s13burger
They fit all of the rb series. With the 26 it requires a custom downpipe, unless you're sporting a right hand drive chassis.
stiergott
Car: 240
i've not had any problems with the old ones. i thought they were a bit thin too, but you have to see them in the car to understand how they work.
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
so where on the top hat site do I find the mount prices????and would you guys do the whole crate motor turboing process to an engine if I ship it to you? and would it cost less than buying a crate motor?
Kansei240sx
Just for some feedback to you other guys, i got the new mount design and they rock face, i highly recommend them for any RB swap. Tophat, my thumbs up of approval goes out to you guys. Keep up the good work.
Joe
im really having a hard time with this one guys
i understand its important for product updates espically in the rb community, BUT tophat is not an advertiser for NICO.
so please, from this point on lets keep any product specific questions like price PRIVATE
thanks guys.
Aznboi64
Does anyone know where I can get replacement bushings for the motor? My friend sold me his Top Hat mounts but can't find the bushings.
syndicatedreamz
I was wondering with these mounts do you still have the beat the firewall in 1.5" for the rb25 swap
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Mike Sims at Top Hat told me that the starter hump on the transmission housing is tight to the firewall tunnel. "It will fit without doing that but as the drivetrain vibrates going down the road it will make a lot of noise in thedrivers compartment."
I dented mine in a little more than an inch, so I hope that does the trick.
OKRB20DET
Car: 1990 S13 coupe
i cant see the pix...
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
pics don't work... photobucket blows...
-Dan
syndicatedreamz
i
Darius wrote:Mike Sims at Top Hat told me that the starter hump on the transmission housing is tight to the firewall tunnel. "It will fit without doing that but as the drivetrain vibrates going down the road it will make a lot of noise in thedrivers compartment."
can u post pics of you engine bay where u dented the firewall place
Darius
Here's a link to the pic of my firewall indentation. I don't know if it will be enough, but that's about as far as I could get it to go without getting violent.
http://nissaninfiniticlub.net/...24767
Darius
okay maybe I'm a moron, but I can't figure out where these pieces of the motor mounts go. I know where the motor mounts bolt to the engine block and the rubber bushings attach to those. I also know how the transmission mount fits onto the 240SX body. My question is, where do the two pieces in my hand in the picture attach to the body and motor?
http://nissaninfiniticlub.net/...age=1
OKRB20DET
Car: 1990 S13 coupe
it bolts to the cross member..but i still would like to see the "new" motor mount pix
Darius
Duh they bolt to the KA cross member, but is the side with the two holes in it supposed to line up with the slot on the cross member? If so, then the angled brace part should line up vertically, correct? If THAT's the case, then my mounts don't line up very well. Can somebody, (hopefully s13burger) explain this a little better to me as no instructions or diagrams were included with the mounts?
Carl H
http://www.tophatperformance.c...s.pdfthat should answer install q's.
stiergott
Car: 240
or you could just call them and ask.
Darius
I think the last thing they want is a bunch of people taking up their time to explain how to install their mounts. The directions Carl provided will save everybody time.
stiergott
Car: 240
personally i thought it was pretty obvious how they bolt together, but what do i know.
OKRB20DET
Car: 1990 S13 coupe
i still wanna see pix of these "new" mounts..and why/what makes em different and better
