I took my car to Bishop Motorsports
http://www.bishopmotorsports.com/ on Saturday to get the car aligned. Pulled the car on and first checked the tire pressures. They were 37 front and 34 rear, exactly where I left them after my last auto-x.
Now before I get into numbers, I should explain what the car was doing before the alignment and what I hoped to change. The car itself handles very well, it tracked pretty straight on the highway. The major issue I had was I couldn't get the car to rotate while braking. In short speak, while trail braking or left foot braking, the rear wouldn't rotate on corner entry. This made me take a wider than I wanted line and thus added unnecessary time. The goal of this alignment is try and loosen up the rear end to get it to rotate under braking.
I also had a full tank of gas when it got aligned (I race with a full tank). The extra weight helps keep the rear down under power, but also probably contributes to the non rotation on trailbraking. The first read out was camber LF, -0.03 deg : RF -1.1deg Toe LF .14 deg : RF .04 total toe up front .18 of toe in
Rear camber LR -1.9 deg : RR -2.3 deg toe LR .05 deg : RR .05 deg The toe in would explain hesitation on turn in especially in transitions such as slaloms, the excessive rear camber and toe in in the rear explains why the rear won't rotate under trail braking.
I can't adjust front camber with out changing the control arms (do any of you know a trick to get a few more degrees of negative camber up front?). So I set the toe at -.05 on both sides meaning I had toe out. This allows for quicker turns but is not recommended for street driving as it will make the car feel twitchy. For the rear I couldnt' get any lower the -1.6 degrees of rear camber. The left side I got to -1.3, but the right wouldnt' go lower than -1.6, so we brought the left up to match the left. We then adjusted the toe to read .01 on both sides. Under load the rear squates and zeroes out the toe making the rear more stable. But the zero toe should allow the rear to rotate under braking. After alignment specs front camber LF -.3 RF -1.1 toe
LF -.05 RF -.05 rear camber LR -1.6 RR -1.6 toe LR .01 RR .01 I have my first auto-x with the new alignment this weekend in Virginia. Jerry (awdjdmtalon) and I will be heading the BRR-SCCA final auto-x of the season in Salem, VA. I'll post later next week what I felt the car doing. The only thing I'm worried about is the long drive down there and how it will effect the alignment settings.
