New adaptation for the Y33 external trans-cooler...
LongBeachQ45
Car: 1997 Q45/Cima Hybrid
So, using BullittAndy's basic Y33 front mounted transmission cooler kit (which received flak about additional backpressure) and Skibane's parallell radiator trans-cooler/after-market cooler combo (which was criticized about it's use of multiple right angles as hose fittings), I have been fielding a few new products from a company that uses true Y fittings with a 35-45 degree spread between two of the connectors. The different materials for these fittings include HDPE, Nylon, Stainless steel, polypropylene, Pvdf, and Kynar. I will be receiving info on the burst tests/melting points of these products, but am thinking the stainless fittings may be optimal. At about $35 per fitting, they may be expensive for some budgets. I will be studying outlet/inlet pressures as well as pre/post driving temperatures. Please let me know if there are any of you Y33 owners who would be interested in this info or these parts.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
LongBeachQ45 wrote:So, using BullittAndy's basic Y33 front mounted transmission cooler kit (which received flak about additional backpressure) and Skibane's parallell radiator trans-cooler/after-market cooler combo
It did? I missed that. How would it form "back pressure"? Very easy to measure with two manometers going down the road.
Isn't Skibane's auxiliary cooler in series with the stock one?
NightRiderQ45
Car: 1998 Infiniti Q45
Thanks.
