d.bright »
https://forums.nicoclub.com/d-bright-u196224.html
Thu Jan 05, 2012 7:05 am
In case anyone cares,
I finally got to drive the car around the neighborhood last night, here's what I observed:
The smell that my Grandmother thought was fuel, isn't fuel, it's burning oil, and it's pretty strong, the first thing I need to do is replace those valve cover gaskets ASAP.
The car cranks fine and idles fine, but there is a lot of noise coming from the transmission bell-housing area that is consistent with a low rumble type of noise and I can't tell if it's engine noise, transmission noise, or possibly an exhaust leak, when I rev the engine it increases in intensity, so I'll have to do some more digging on that unless anyone has some suggestions?
As soon as I backed out of the driveway and came to a stop, the car died on me, I think this is the MAF, I'll clean it out tonight and see if it makes any difference.
There are a lot of squeaks and rattles coming from the dash and front seats at idle and I'm sure it's just from the age of the car, does anyone know of any common squeaks/rattles that occur on this car and how to fix them? I have an interior noise kit from what I worked at Toyota a while back that I could possibly use on the dash.
Other than that, the car seems to be alright, the passenger side window won't go down very far before it acts like it's stuck, I'll take the door panel off and troubleshoot that myself. I'm also planning on possibly taking the entire engine out and resealing it from top to bottom, I can take the plenum off and replace all those hoses while I'm at it, and possibly replace the timing chain if it's worth it. And I can also thoroughly clean out the torque converter while it's out to get rid of any built-up metal shavings lurking in there. And I can replace the motor and trans mounts too.
I'm open to suggestions/comments and thanks for everything so far!
