elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Wed Sep 24, 2003 9:28 am
Hello....... Welcome to NICO!!
Ill just go in order.....
Thats a normal sign for ill-maintenance...... Do a FULL flush and Tstat change...... Do a search, i remember posting something VERY detailed on how to lump those together......
When the engine starts getting hot, the computer starts retarding the timing (IE firing the spark plug sooner) to cool the engine...... And it does work, to some degree......
<assuming the Qs intake is the same idea as the J> THe intake system is VERY, VERY low restriction..... Plug those holes up <now> and put an OEM filter in..... You wont notice any better/worse performace with a NEW oem....... Their only $7 from Joe........
if the filter you took out was looking really bad, then putting in the K&N did help since its clean...... K&N is for crappy cars, and the J30 is not one of them!!!!
To help performance, you need to make sure everything in your intake tract is clean...... TB, plenum, etc...... Do a search, its all been covered.......!
