lrayvick »
https://forums.nicoclub.com/lrayvick-u131195.html
Mon Jul 27, 2009 4:02 pm
Can't rev it up quite yet, and I do appreciate all the help I can get.
Anyway, today I drained the fuel tank of about 7 gallons of some stinky stuff. Removed and checked the fuel filters, pump, and lines then reassembled and tested. Got fuel to the carb.
Now the hard part. Pulled the carb which was kinda dirty in the float bowl. The float needle was stuck so that's why it wasn't getting much fuel and both main jets were open but the smaller one was almost plugged. I also noticed a broken external connection between a vacuum part and the throttle linkage. Will put up a pic if anyone is interested.
I suspect the broken connection has to do with the starting and choke system. Are these carbs even sold rebuilt any more? I doubt it. I did find a carb rebuild kit for $65 plus shipping on line. I might try and fix the broken connection but may try and smog it first - here in CA it's very diffectult to pass smog if there is any aftermarket motor stuff so I won't be going the Weber conversion route.
I also found it has about $270 in backfees - the fees you get charged anyway by the DMV for failing to register your vehicle each year. So the carb fix better work or this is a parts truck.
LRAYVICK
Modified by lrayvick at 8:15 AM 7/28/2009
