New 81 720 pickup
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
marclamb1112
Car: 1981 Datsun 720 2wd pickup standard 5 speed
Hey everyone i just bought a 2wd 5 speed datsun 720 pickup my friend who i bought it from did a tune up but it likes to stutter and not turn off when you try to shut it off so i have to put it in first and essentially kill it. now my friend said he thinks its a problem with the carb/choke i just wanted to know if anyone has seen this and if so if a new carb kit will fix the problem.
also im trying to figure out what size my gas tank is but i havent been able to find the information anywhere. a little help>?
i will be uploading pics of my truck soon. thanks for help!
PEZi
Not 100% sure on the gas tank, but the problem sounds to be the cutoff solenoid for the carb. Had the same problem before in mine.
marclamb1112
thanks i got the rebuild kit for my carb so my buddy is going to help me put it in hopefully that will fix the problem. definatly needs a lot of work but as of now i gotta do stuff a little at a time because money is tight. any tips on how to help the engine perform better?
poopypants
Car: 1981 720 KC 4x4
yup.... rip off that old carb you got there and throw on a weber 32/36... also depending on your emissions laws take off the cat and maybe even get some headers.
The only other things that will really wake it up is get the head redone, port and polish the intake and exhaust ports and get them port matched as well.
Pretty much all you can do to make it breath better... maybe a diff cam? but all depends on where you want your power band.... anything more begins to become MAJOR modifications and will cost a pretty penny... might as well swap for a bigger motor at that point.
shakercrouch
1987 Chevy C10
Polish actually takes away power as it screws with the air flow but porting is still good.
marclamb1112
Tryin to get stuff done but keep running into more problems. recently muffler fell apart because of the idiot before me but it gives it a nice sound XP any ideas on how to lift the front end?
Return to “Datsun 720”
