evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Aug 13, 2012 12:49 pm
It counds like allthe posible issues have been delt with. Make sure you have a good spare, tire iron and jack in the car. It's also a good idea to keep some jumper cables in the car. CHeck the wheel bearins for play, make sure the belts and tight and show no signs of wear, and the all the coolant hoses are in good shape (be sure to look a the heater hoses and intake warm up hoses).
Pump gas is fine, the early cars came with bronze vave seats, most have been changed in the last 40 years so I wouldn't sweat it unless ou develope a miss a idle, should be fine for a 1k drive. The octane isn't the issue it was the lead and the valve seats, ask what the seller normally runs, most likely 87 octane will be just fine.
The wipers and headlights suck. Avoid night or rain travel if you can.
Suspension wise if the chassis is solid the car sould be sine for the trip, the tie rods and ball joints are seaed from the factory but again most likely have been changed in the last 40 years and if you get an oil change it's a good idea to grease up any joint tha now has a grease fitting
These cas and pretty simple and very ependable, honestly the thing I'd worry about is those webber cabs, they are far more complicated than the stock SU's and don't really offer any performance advantage, I'd swap them back to stock. The DGV's tend to puddle in the adapter's and cause a real rich condition when taking of from a light, for me it's SU's, tripples,or fuel injection.
