I concur, do all of thisnissanfreak12 wrote:How to check the fan clutch, with the car not running, push it hard enough so it turns. If it stops almost immediately, its bad. If it makes more than two full turns, its bad. It should really only make one full turn, maybe. Should have some resistance. Easy way to find out.
Ac system, if it doesn't cool, no refrigerant. You have a leak somewhere, point blank. You could do a recharge, but you will either be doing it again in a short time or next summer. Besides, you also need to find out if you have r-12 or 134a in it.
Coolant flush, I have had luck with the prestone one at vatozone. Try and find one with a T so you can hook a hose to it and do it correctly. If the radiator is gunked up, its better to replace it, get a nice aluminum one, one of the best investments I did for the cooling system.
If you look into the 120k kit, get silicone hoses for the bypass hoses, upgrade to the Ramey Z idler studs, and the stiffer VTC springs. Will not regret it, especially if you plan on keeping it. This car can and will get expensive, but just don't cheap out on parts, you will be doing that part twice.
I concur that you concur!!t.mcginley.jr wrote:I concur, do all of thisnissanfreak12 wrote:How to check the fan clutch, with the car not running, push it hard enough so it turns. If it stops almost immediately, its bad. If it makes more than two full turns, its bad. It should really only make one full turn, maybe. Should have some resistance. Easy way to find out.
How the hell did someone get a NA radiator in with all the piping for the intercoolers? I had a b**** of a time with a TT radiator getting all the piping in on my swap.twinturbozxtacy wrote:make sure its got a tt radiator, i had a tt swap with a na radiator, no go... t stat is a real possibility. id do that before driving it too much. running hot is never good. also your temp sensor could be off... lots o possibilities. what ever you do dont let it over heat.
Yeah how the hell?! Please explain!nissanfreak12 wrote:How the hell did someone get a NA radiator in with all the piping for the intercoolers? I had a b**** of a time with a TT radiator getting all the piping in on my swap.twinturbozxtacy wrote:make sure its got a tt radiator, i had a tt swap with a na radiator, no go... t stat is a real possibility. id do that before driving it too much. running hot is never good. also your temp sensor could be off... lots o possibilities. what ever you do dont let it over heat.
Here are the pictures of my new buy. Drove a little ways up the mountain behind me today and took the pictures. I replaced the thermostat today and it seems to be running fine now. Cept for that damn sounds when I get on it, it doesnt sound bad it just sounds like a ford expedition getting up to speed or something. Ill take a video of it and upload it here shorty.nissanfreak12 wrote:Congrats on the purchase, and welcome to NICO!!! Post some pics..
First thing to do is read over this...
everything-you-need-to-know-about-the-z32-t508377.html
Look at the bottom of the page, talks about the 6 P's, go over all that. Do you know if the timing belt has been changed? 120k service? If unsure, do it. Don't go cheap on this, it normally runs about $500-$600. This is what keeps the engine going and if it breaks, buh bye engine.
The fan clutch could be bad if it has a loud roaring sound or it could be engaging because it actually is hot, and its trying to cool down the engine. My advise, flush the system. Use a good coolant flush to do this. It is possible the thermostat could be malfunctioning and/or the radiator could be clogged. Make sure you have a fan shroud with a stock radiator.
Are you running AC when it gets hot?
Does the electric fan turn on?
From what you described, it sounds like the fan clutch is out. Still a good idea to do the flush. keep us posted.
NolimitZ32 wrote:Very clean, great pickup man.
NolimitZ32 wrote:Holy jeebus, 5500 for that?! That's a steal man!
without thread jacking lets say he had a rubber mallet and took it to the sides of the rad.....nissanfreak12 wrote:How the hell did someone get a NA radiator in with all the piping for the intercoolers? I had a b**** of a time with a TT radiator getting all the piping in on my swap.twinturbozxtacy wrote:make sure its got a tt radiator, i had a tt swap with a na radiator, no go... t stat is a real possibility. id do that before driving it too much. running hot is never good. also your temp sensor could be off... lots o possibilities. what ever you do dont let it over heat.
