new 300tt with BOV setup confusion
97sr240
Car: 94 300zx TT
First id like to say Hello, new to the site. I have been doing alot of searching and cant seem to find an exact answer.
I bought a 94 300zx 2 seater with a TT swap and it has blow off vlaves installed with both going back to the same vaccum source, (picture below) and im getting some iradic idle at times and im thinking this is the cause but it has an aftermarket front mount intercooler setup and none of the stock piping or the recirculation valves. Any advice or information would be greatful. Thanks
Current Mod list:
60k kilometer on JDM Twin Turbo engine with factory rebuild t-25 turbos.
EGR delete kit with EGR plenum block off plates,
Carbon Canister rerouted under plenum water lines for easier plenum pulls
94 spec Cas sensor and Main wiring harness
bronze shifter bushing
370cc fuel injectors
Stillen tuned ECU, stage 3
Stillen POP Charger intake system
RS blow off valves
AC Autotechnic adjustable fuel pressure regulator with liquid gauge
Greddy catback exhaust, with stainless steel test pipes.
4 bolt 2.5 inch twin turbo stainless steel split downpipes
Z1 16lb flywheel and 6 puck ceramic 600hp clutch with new clutchmaster throw out bearing.
New clutch slave cylinder and rebuild master cylinder.
One piece stainless steel braided clutch line
underdrive pulley
ThisIsSparTTa
Car: 91 300ZX TT 2+0
BOV are recircs except they are designed to vent to the atmosphere. By rerouting them back to the intake, they've just made them act like recircs. This would not cause an idle issue in either case as they do anything under pressure.
I wouldn't suspect a FMIC to cause idling issues by itself either.
Start with the 6Ps sticked at the top of the forum and pull your ECU codes for a start.
97sr240
Car: 94 300zx TT
Thanks for the reply.
I know alot of people have said they have had some issues with it and not use atomospheric bovs. Does it matter if the bovs have the same vacuum source? and just to clarify an ecu reset wont remove my tune will it?
97sr240
Car: 94 300zx TT
I tried to pull my ecu codes but when I try to go into diagnostics mode it doesn't do anything the light just stays solid does that mean my ecu is bad? it has a stillen stage 3 tune.
ThisIsSparTTa
Resetting ECU just resets the memory for its auto adjustments. Your tune is burned to a ROM (read-only) and can't be reset without flashing the chip itself. Sometimes the potentiometers for the diagnosis mode go bad. You can repair it yourself or send it to TT.net member DVDBurn. The better and easier long term solution is to grab a $30 Consult to USB cable from eBay, and then you can read your codes and all the sensor readings with free ECUTalk software.
