sololock »
https://forums.nicoclub.com/sololock-u103539.html
Tue Sep 21, 2010 12:35 am
i recently finished up a rb20 swap into a s13
the car will not rev high and boost, sounded as if it was misfire.
I replaced everything else
Maf tried n60, and n62, and oem
changed plugs to iridiums
NO boost leaks
compression is 150-154 in all 6
ran code on ecu, came up as 34 54
so i tried to bypass with 1k ohm resistors
( i know bad but wanted to see)
ran a little better but not how it should, still has a misfire and still shows code 34
Do i have to drive for awhile or 34 codes go away asap?
what else could be making it run like that
