This topic has been discussed in multiple threads. Here's a few.F10inSD wrote:Hi Team,.. 2. Is it normal for the outside temp to always read about 7-10 degrees hotter than the actual outside temp?...
Outside Thermometer Inaccurate post6499462.htmlRogue One wrote:outside-temp-sensor-t547279.htmlHelium2 wrote:Where is it?what-are-these-wires-for-behind-the-gri ... re%20these
I'm not sure. Where did you read that?F10inSD wrote:Hummm.. Ok so then is it possible to have it turned off by the dealer like I read online?
It's in the owners manual. You should try reading it sometime.tsumeone wrote:I'm not sure. Where did you read that?F10inSD wrote:Hummm.. Ok so then is it possible to have it turned off by the dealer like I read online?
ACTIVE ENGINE BRAKE
The Active Engine Brake function adds subtle deceleration by controlling CVT gear ratio, depending on the cornering condition calculated from driver’s steering input and plural sensors. This benefit to easier traceability and less workload of adjusting speed with braking at corners.
The Active Engine Brake also enhances braking feel by adding subtle deceleration with CVT gear ratio control according to driver’s brake pedal operation.
The Active Engine Brake can be set to ON (enabled) or OFF (disabled) through the Vehicle Information Display “Settings” page. See “Vehicle Information Display” in “Instruments and Controls” for more information.
Section 5-42: Starting and driving p.315
Gotta love the know it allsRogue One wrote:It's in the owners manual. You should try reading it sometime.
Everyone is entitled to their informed opinion. However, the misunderstanding is on your end. I was was replying to tsumeone's question "I'm not sure. Where did you read that?" It's a question on where information was obtained from, nothing more.tsumeone wrote:I'm telling you guys that you're wrong. That says absolutely nothing about disabling the engine brake when going down hills, which is what the OP asked about. You don't need to be rude about your misunderstanding.
That was a question for the OP. I was asking where they read downhill engine braking could be disabled by the dealer. You replied in a snide manner that I should try reading the manual sometime (which I have). The manual has no information on disabling downhill engine braking. The misunderstanding is on your end and I would appreciate it if you, as a moderator of this site, would not be unnecessarily rude when someone is sharing their factual experience with a 2014 Nissan vehicle which you do not even appear to own.Rogue One wrote:Everyone is entitled to their informed opinion. However, the misunderstanding is on your end. I was was replying to tsumeone's question "I'm not sure. Where did you read that?" It's a question on where information was obtained from, nothing more.tsumeone wrote:I'm telling you guys that you're wrong. That says absolutely nothing about disabling the engine brake when going down hills, which is what the OP asked about. You don't need to be rude about your misunderstanding.
I have a query in to Nissan Tech to try and get a more definitive answer on turning off or disabling the engine braking system.
While that's true, I'm worried about the consequences of the extra stress on the CVT transmission. It might save me brake life but that's requiring the transmission to do more work. Nissan hasn't given us a 10 year warranty on the new transmissions so I don't want to put extra load on it if I can avoid it.RyleyinSTL wrote:^^While the vehicle might be engine braking down a hill at 2500RPM it isn't actually consuming as much petrol as if you were revving the engine at 2500RPM. This is accomplished by the magic of computer controlled everything. You can increase brake life and still get good MPGs. Everything Nissan does in this respect is about a higher number for the EPA MPG cycle so if engine braking consumed more fuel (on average) they'd have tossed the idea.
