new 2000 Xterra owner
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
new two xterras but not Nissans, need stickies, and FAQ but no official stickies on xterras? Any way 165k 2000 xterras black grey cloth. Doing all reg maintenance, any thing I need to watch out for pics to fallow
jbracy7
jbracy7
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Anything that applies to the D22 Frontier applies to the Xterra. Same vehicle for the most part.
Do the timing belt if you don't know when it was done last.
Change fluids, check belts, hoses, etc. If any of that stuff is original, it's 16 years old and likely in need of replacement.
Auto trans - (assuming it's an auto) - check color of the fluid. If brown or burnt, consider a flush.
Plugs, cap, rotor, wires would be a good idea.
Otherwise, drive it.
jbracy7
Thx for the information, Doe's the d22 frontier front fascia fit or does it require extensive custom work
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
Frontier fascia is a little bit different but can be adapted to work. The 98-00 Frontiers have a body color steel strip under the grill that's not there on the Xterras, and the bottom of the turn signal part of the front fender wraps around a little further on an Xterra than it does on a Frontier. I have Xterra fenders on my D22 pickup and had to trim about an inch off the fenders there to get them to fit properly.
As I see those alloy wheels, look at them closely for cracks. Believe they had a TSB or possibly an outright recall on that style of wheel. The cracks will be evident on the spokes if present.
jbracy7
I see no Cracks,none yet anyway. Does the vg33e have the dammed chain guides,because i know that rattle,atleast i think i do
jbracy7
Noob swap question alert.will a vg30de fit inside the strut towers. is it a direct swap
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
um....truck doesn't have strut towers.
What you suggest would not be a smog legal swap, but if you don't have inspections, so be it. Unless you're dropping in a TT motor, the modest HP gain wouldn't be worth the trouble unless your VG33 is dying anyways.
jbracy7
Vg33 is starting the death roll. 202000k on the odo,vg30de is lil easier to rebuild. big back orders and no aftermarket support has plagued me so far. A vh41 is a dream,but custom fab will burn up my budget fast. How ever i still dont think any swap is possible
jbracy7
Jegs has alot to offer xterra,jegs+jim wolf almost complete with my build sheet
