New 17" rims, but steering wheel shakes at higher rpms...
NissanSupraGTR
Car: 1990 240sx SE hatchback
Just as the title says. Bought some used tenzo rs-5s with tires for $200, they seem pretty good and the price can't be beat. Only problem is, besides em gettin dirty so fast, is that below 3000 rpms the steering wheel jiggles back and forth. It's nothing i can't control, but it makes my arms vibrate :/ Also installed the tires backwards, plan to fix that soon, but could that cause the shaking? If not, how do i fix it?
adrianfromthecastle
Car: 1992 Nissan 240sx
I'm thinking your tires need balancing. Take it to a tire shop and get them balanced, or at least the fronts.
teddy
Car: Saab Turbo and MR2
Well having the tires on backwards isn't a good thing. When's the last time you had an alignment too?
Chukidori
if they are directional tires, you need to put them right way. NOW
I hear its a quick way to **** them up.
NissanSupraGTR
well i had a brake check done and they switched the tires to the right positions, and the vibration is a lot better. Still feel a little bit, but its only in a certain range and nothing i cant handle
