New '08 QX 4x4 Owner:Need advice on all terrain tires.Anybody?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
drogers
Car: 2008 Infinity QX56
I just picked it up and I would like to go to a mild off road tire like BFG or equal all terrains.Any suggestions? I did a google search and forum search but came up empty. Thanks
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
You should check with http://www.tirerack.com
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Welcome to NICO!
I had the older version of these on my old Hardbody, They were great on road and with light off road. I would really like to see pics if you get these.
Dueler A/T Revo
drogers
Thanks,that is the one I have been leaning towards.Tire rack only lists one size in a 20". I'll have to see if it fits properly.
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
I don't know for sure but I have seen them with ridiculously large rims and they fit. You've got to show those off.
drogers
I've been driving one ton crew cab 4x4 diesel trucks the last 10 years.If I'm gonna drive a SUV it's gotta at least be 4x4 and have some off road tires.
bkelly
Car: Infiniti QX56
I ran Bridgestone Dessert Duelers on a 2006 QX56 and totally loved them.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I highly recommend Toyo's Open Country A/Ts. Great blend of offroad capability with good road manners. They're very quiet for an a/t, too.
C-Kwik
Tire Rack lists the OE size as 275/60-20. Selections appear limited for that size in all-terrain tires. The Bridgestone Revo's are likely the best choice of the ones available.Though, that particular size has a tread depth of only 11/32nds".
Another option might be to go to a slightly wider tire. I'm not sure what the wheel width for the QX is, but perhaps a 285/55/20 might be an option if you're looking for a the BFG A/T KO. I have that tire on my Titan. Rides and feels great. A little noisy, but not bad. They are a heavy tire though, so expect a hit in gas mileage with them (mine dropped by about 1 mpg vs the OE Wrangler SR-As).
The BFG A/T KO's have a good reputation for handling a lot of miles and tend to have high weight limits (especially in sizes that allow the tire to be pumped up to 80 psi).
However, make sure that you consider what you plan to use the vehicle for. The KO's tend to scrub a fair amount at the cornering limits on my Titan. Probably due to the very square shoulders. Then again, this wasn't a tire designed to be tracked either. I towed a trailer full of dirtbikes shortly after getting the tires and it handled the tow and the dirt just fine. My Titan is also only 2WD with an open diff.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
