Teknic73 wrote:Well i figure it's time to introduce myself now that I have enough questions to ask you all
Cool!
Teknic73 wrote:I had been lurking on this forum a couple months before i finally picked up the M, and i must say the positive reviews from a lot of you influenced my purchase
Good! The car is an amazing deal for the money. Has some things that you need to watch out for, and I suspect (given my past experience with Infiniti) that some of the repairs will not be inexpensive, but the overall results are still awesome!
Teknic73 wrote:#1 The first thing that started to annoy me was the this puttering noise when i would get on the pedal from dead start or even when moderately rolling. szhosain suggested using BG44K, which i should order right about now.
Probably a good idea! If not successful, then a full injector rail flush to get rid of deposits may be necessary.
Teknic73 wrote:#2 This drives me NUTS every time i drive in reverse there is clicking sound, and immediately when i put it in drive out of reverse. my guess is the axle.
Hmm. That is unusual. I would also suggest to check to make sure that something in the rear brakes are not dragging in reverse. Changing the rear differential fluid is also a good idea.
Teknic73 wrote:#3 The transmission is not as responsive in manual as i wished it to be, even w/ the VDC off. I read somewhere about disconnecting the battery to reset the ecu, but i can't find that thread.
You probably do not need to reset the TCU or ECU. After driving for 15 or 20 miles, the transmission learns your driving habits and will do the right thing from that point on.
There is also a TSB available for the transmission TCU that should be applied - this will improve the responsiveness a lot! I forget the exact TSB number, but you can do a search for it here in this forum.
Teknic73 wrote:#4 Another concern that i had is w/ the amount of abuse the transmission can handle. Is it safe to have it in Manual 95% of the time. I tend to leave it in 4th on the streets and in 5th for the hwy. I try not too shift a lot on the streets as if i had a manual, but do i need to be this concerned at 65K miles. Also how bad is it to slow down by downshifting and no brakes?
First, I do not think that driving it in manual will do any harm - I do the same as you. I drive in M4 all the time on city streets, or going uphill (sometimes even shift down to 3 if it is a long gentle hill) and then only shift to 5 on the highway.
Although I do not downshift instead of braking, I can't see this being a big problem either. Might put a bit more wear and tear on the transmission, I suppose, but this should not be a major issue at all, IMHO.
Teknic73 wrote:#5 The other day I was driving to the office when I saw a black Audi coming up behind pretty fast. Once he passed me i realized that it was an S4 so i decided to put the M to it's 1st freeway test . he passed me doing at least 90 so i had to get on it. Long story short i was about 1 1/2 cars behind him for about 2 miles and he could not lose me. That was the day i had to to my M.
I have to admit that this is a bit surprising, although the M is a surprisingly fast car. It does 0-60 in 5.4 to 5.5 seconds, and I have beaten some interesting cars with it (including a Ferrari 308 of some sort). Loads of fun. The S4 is a very fast car, so it should do better than the M45, but it could depend on traffic too and the driver.
Teknic73 wrote:The only thing that worried me though is the front felt like it started to slightly hop and shake @ the 125 mark. I thought that it might be an unbalanced tire, but wouldn't i feel that at even 80mph? I have not tried going that fast again since i tend to say below 3 digits but has anyone experienced this?
I would strongly suspect an unbalanced tire, and yes, it might show up at 125 and not at 80. In fact, I rarely exceed 100 to 110mph if I am not on freshly balanced tires (which I do every 2000 to 2500 miles regularly).
I would also make sure to see if the lower engine cover and oil cover are properly in place. I doubt this would cause a serious hop and shake problem, but in windy conditions, it may make a bit of unsteadiness.
FWIW, I have taken this car to 130 to 135 mph (on new, freshly balance tires only - no patches) without any problems whatsoever.
Teknic73 wrote:#6 lastly what kind of spark plugs and wires do you guys recommend? are there any Iridium plugs for the M?
Hmm, here I would recommend sticking to OEM plugs religiously! Infiniti and Nissan engines are notorious for problems with other "good" brands. People have seen broken plug parts inside their cylinders with others - Bosch is the one that is highly rated, but unsafe for Nissan and Infiniti engines! The OEM plugs are inexpensive enough compared to other good brands that this is not a risk I would take with my engine.
Z
