Never seen this before...and a little something for bh.
s13beast
Car: 94 5spd silvert S14 SR
91 hatchback dd
Okay so my driver side rear wheel sits farther in than my passenger side wheel. wtf. nothing appears to be bent. And this is gunna jack up my wheel fitment in the future also. Any ideas? Also bh im rocking the riskey devil sticker i ordered a while back. thanks.
Normal:
Stupid:
maryjane
someone tagged a curb.
Felipe
Car: abcdefghijklm nopqrstuvwxyz `1234567890-= ~!@#$%^&*()_+
over fenders....
Dire91
Car: 1997 Nissan 240sx SE
Weird, the line looks off on the drivers side when you look at the door then the rear fender.
s13beast
91 hatchback dd
Dire91 wrote:Weird, the line looks off on the drivers side when you look at the door then the rear fender.
Yes. Its called door sag. Vert door are like 30 pounds heavier that coupe and hatch doors so sometimes they sag. I have coupe doors now. i need new hinges. and apparently a new rear suspension.
ChampaignSilviaS14
Car: S14
Do you have any adjustable arms? RUCA's, Toe arms?
ViolentRunning13
Bad sticker placement.
i240sx
Car: 240sx coupe
i agree..i though i was th only one...my driver front rim is out more then my passanger... my passanger rear is out more then my driver rear...my previous 240 also had this problem..i think its a 240 think...
s13beast
91 hatchback dd
ChampaignSilviaS14 wrote:Do you have any adjustable arms? RUCA's, Toe arms?
Nope.
ViolentRunning13 wrote:Bad sticker placement.
Sorry to disapoint....
Tsukiko
Car: 1990 240sx fastback KA24E
check your rear upper arms. There are camber bolts at the inside ends. i had this issue a long time ago then realized some a$$ set the camber differently before i bought the car. I wouldn't be surprised if your camber is slightly off on one side.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Check all the arms, LCA, RUCA, check the toe rod and traction rod check all that stuff back there and make sure nothing is bent. Your subframe could be bent but that is really hard to do so i doubt its that. Also do as mentioned before and get your alignment checked out you may be worried about something that is visual. I know the front of my cars camber is the same however the wheels arent the same flushness on both sides (not extremely noticeable but still lol)
GOOD LUCK!
S13Teddy
Car: R32 Skyline, S13
It's like that on all 240sxs. The subframe is offset I believe. My car is also like that, but hitting curbs surely doesn't help.
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
i240sx wrote:i agree..i though i was th only one...my driver front rim is out more then my passanger... my passanger rear is out more then my driver rear...my previous 240 also had this problem..i think its a 240 think...
My pass front is like 6mm more to the outside than my driver. My friend who works on alot of 240's at his shop says this is very common. He thinks Nissan's build process was a lil flawed. Mabye yours is the same issue (obviously opposite side tho) not sure on those rears tho
240sxs13sleeper
Car: space shuttle
idk .. but i heard that all cars have a slight natural lean to them.. thats how all cars are built because all of our roads and streets have a lean to them too. so i figure the wheels on one side are in a little.
ChampaignSilviaS14
Car: S14
Being that low you need to have adjustable arms, at the least RUCA's and Toe arms.
s13beast
91 hatchback dd
ChampaignSilviaS14 wrote:Being that low you need to have adjustable arms, at the least RUCA's and Toe arms.
Yes sir. I didnt know so many s13s were like this. Ive owned 4 and this has been the only one. If i get the pbm RUCAs and all that jazz, would i be able to push that wheel at some? Its really bothering me.
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
sooo let me guess
you got some JDM tyte coils and now wonder why the car sits funny?
u might of heard of it.
alignment
u need one badly
ChampaignSilviaS14
Car: S14
s13beast wrote: Yes sir. I didnt know so many s13s were like this. Ive owned 4 and this has been the only one. If i get the pbm RUCAs and all that jazz, would i be able to push that wheel at some? Its really bothering me.
Yes, its called camber.
You are going to need toe arm's too to get a proper alignment. Factory toe arms can't go far enough to match that camber and it will eat away your tires.
s13beast
91 hatchback dd
hbpignosePA wrote:sooo let me guess
alignment
u need one badly
It had one not long before i bought it.
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
Mine was similar & I replaced the subframe with a known straight one and got some spl solid aluminum bushings and now its only like 3mm to the pass. side, which is natural for 240s. The previous owner of my car ran it off in a ditch on the driver side and the SF didn't "looK" bent, but did when I compared it with the good one. Also didn't help that the driver side rear rubber bushing was blown out cause of it... hope this helps
BrianHarte
Car: 180sx
Hot stickers for sure.
