95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Sat Feb 03, 2007 5:24 pm
maybe not related (i had the same with trying to get a TT engine to idle, but without black smoke, but give it a shot), if there is black smoke, then a non-turbo engine would be running rich (or in other words, there seems to be gas escaping the combustion chamber without being burnt), if it is a turbo engine, then might be that or the turbo is about to go
first things first, do an onboard diagnoses using the Engine Control Unit (ECU), the following works for all 1993-1995 J30 and J30t models, it is located in the passenger side (if you are sitting in the passenger side, it would be where your right foot is when resting it against the right side wall), remove that cover (becarefull not to break the clips) remove the three screws to free the ecu (keep it pluged to the wiring), you will see a screw looking thing that has a whole right beside it in one of the edges of the ecu, turn the ignition to the on position (dont start the engine), rotate that screw clockwise untill it stops, and then fully counter-clockwise untill it stops, you will notice a red LED that would start blinking if there is something wrong, the blinks refer to numbers, the decodings are available in this forum, let us know of what comes up
make sure that your Mass Air Flow sensor has a clean connection, also make sure that your ignitor chip's connections (2 connections) are clean and that no water has gotten in...., check the gas cap, when you open it, it should make a sound of air escaping, also make sure that your oil fill up cap is closed tightly, and that the dipstick is in place fully pushed in (yes all of the above can cause the engine to run rough) turn the engine on with adjusting the rpm high enough to keep it working, lean down so your ears are close to the engine, try listening for a vacuum leak sound along the sides and the back of the engine, it would sound like (psssssshhhhhhhhh... i wish i could post a sound clip), if there is one, then locate it and connect the vacuum line accordingly, i doubt that this is the problem, as the engine will not stal unless the vacuum leak is big, but it is worth a try (always try the easiest things first)..... my engine was running very rough once because the fuel regulator vacuum line was not connected
now with the engine running (dont worry, this wont harm the engine at all), unplug one coil at a time (the connection to the coils that are right above the spark plugs), when you unplug each coil, the engine's rpm should go down (do it fast enough not to make the engine stall, so you wont have to start it each time), try to find a coil that would not make a difference in rpm, and that would be the problem
i guess that this is a lot to digest for one post, let us know which one of these is the problem, hope this helps man, i know how much that sucks, good luck, i'll be checking again later on tonight,
