240crawler »
https://forums.nicoclub.com/240crawler-u29033.html
Tue Aug 15, 2006 9:53 am
I have had the same problem before; that is why my S13 is still on dino. I had a 92 Crown Vic with Interceptor engine and Handling package. Sweetest 4-door car ever (sorry M5). With 84,000 on the clock, my feeble mind decided to go from Motorcraft 10-30 to Mobil full synthetic in the same weight. Within 2 days, I lost 4 quarts, at $5.99 each, and had the entire engine bay covered. I also had this problem with a 91 Integra of my girlfriend's. She decided to use Castrol full synth because She saw Danica Patrick advertise it. When she had it changed (at Wal-mart noneless), oil came out everywhere. I now believe that dino oil is far superior for a used engine.
On another note, after trying to find out which dino oil was best through book and net research, I took it into my own hands for some informal testing. The results would have shocked anyone.
I used 3 identical 8hp Briggs side shaft engines connected to water pumps. I loaded the pumps in a creek, ran them at max engine speed for 24 hours and looked at the oil when finished. Needless to say, this is a test that holds weight with me.
My findings were that Shell Rotella in sae 30 held up the best. The oil was still clear, still slippery, and the motor did not burn one drop. That could not be said for the other 5 oils.
When I related my experience to my uncle who runs a repair shop for Caterpillar and Cummins diesels, he reminded me of the time we pulled main and rod bearings out of a 425 Cat with 495,xxx miles. They looked brand-new. Caterpillar reccomends changing at 150,000; 400;000; and every 250,000 after. This engine since new ran on 11 gallons 10-30 Rotella and 1 gallon Lucas oil stabilizer. The truck only saw oil changes every 20,000 miles.
Before anyone says that the KA and a Cat are like apples and oranges, let me tell you something often overlooked. The engine in an over the road semi tractor is the hardest working engine in existence. They routinely pull a load of 50-80,000 pounds, always at redline. A Cat engine has oil squirters just like any high-performance car engine, 4 valve heads, direct injection, and most important--it can be modified for more power. There are upgraded turbo-intercooler packages for these motors, modded fuel pumps, rear-end gearing swaps along with trannys to suit any need. They are modified for their type of performance; not on a track but up a hill. A 425 Cat starts life with 425hp at 2250rpm and over 2,000ft lbs between 1400 and 2500. They can be tuned up to 750hp with exponential increases in torque.
