I even took off the old connector and as it turns out it wasn't really faulty, but it was broken and crap so I had to replace it anyways.
So then I found a potentiometer and set it to 2.5k Ohms resistance and hooked it up directly to the wires to simulate cold start resistance (the car was cold), but no change. I kept changing the resistance low to 2.5k with the car running, but no change in idle. I tested the connector wires and they are getting 4.8V of power, but the thing is I get no continuinity anywhere.
I've been staring at this FSM page for some time now, but I'm just lost. Maybe I'm not checking for continuinity properly? Can there be 4.8v to the signal wire if there is no continuity? Please help
