Netxt time you change the trans. fluid..........
voolover
Car: 2002 pathfinder-90 Axxess
Try this...it worked for me......
After you drain the pan disconnect the cooler hose from the left (driver) side of the rad. Set the regulator on your compressor to no more than 30psi and apply air to the hose you just unhooked. Now the magic....thought the trans was drained??? Watch and see how much more fluid comes out!!
I also changed the filter and the refill was 7 qts....so probably 2 or so stays in the converter....I used wally world fluid for the 1st drain and fill, with the final refill useing NAPA Dexron lll.
This is on a 2002 pathy with 60k.....Changed all the other juices as well and with the $$$ saved from what the shops want for a 60k service bought a Hayden cooler for the trans,Warn hubs and a full tank of gas!!
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
Cool Idea Thanks!
