Amays U G37S »
https://forums.nicoclub.com/amays-u-g37s-u167091.html
Tue Dec 21, 2010 6:17 pm
Alright.
You can't access the router, remotely. You can but you have to connect into a host computer first.
Are you trying to connect in to run the software? You can use, LOG ME IN, which is a program that connects to a host from your PC, but it is at a price. I do not recommend using the software that is labeled REMOTE DESKTOP CONNECTION because you have a secure network, and if you add this port to your router, I can then access the router, if I know the log in WEP or WPA key for your router.
If you are trying to connect to a remote host, the easiest way is through Log Me In. But, With a VPN, you have to have a VPN/Firewall to connect to the network, to log in through that securely, then connect it to a host, or the "server". Once this is established many people can be on it at one time, or other desgniated systems, but users cannot be on the pc at the same time.
(we don't do VPN installs, I sub it out to one of business parters. But I do setup networks. I have a degree in it and tons of exp. if it means anything)
Ask your questions away.
