ghx407 »
https://forums.nicoclub.com/ghx407-u51111.html
Tue Oct 13, 2009 2:54 pm
The 1% THR value is to tell the ECU to apply the Dec Air settings at 1% throttle or less (basically idle). Here are my settings as an example:
Ne1=1000 RPMNe2=2000 RPM
Dec Air:THR=1.0%Ne1=0.9% (1.1% if the car is very cold or if the AC is on)Ne2=1.9%
Basically, the SAFC will tell the ECU to disregard sensor inputs and to apply instead the Dec Air settings (to inject at Ne1's RPM the amount of fuel corresponding to a 0.9% Air Flow and to inject at Ne2's RPM the amount of fuel corresponding to a 1.9% Air Flow) whenever throttle input is 1% or less.
