And if you look closely directly above the middle of the wheel you can see where his quarter panel has indeed buckled in two spots.JDM-Silvia wrote:This guy is running 18" the same rims and offset..He managed to pull it off in a coupe. I think it looks sexy without a kit and just low and wide.
50 rears30s will be good for 10 +10nismofly wrote:20mm overfenders up front, 30mm rear
theyll look great
