SanoSuKe wrote:Lol, you're fine. Like what he said, toe is what mostly causes tire wear. Don't touch any bolts or you're gonna get the toe out of spec.
You don't want to knowAlexN09 wrote:SanoSuKe wrote:Lol, you're fine. Like what he said, toe is what mostly causes tire wear. Don't touch any bolts or you're gonna get the toe out of spec.
Just out of curiosity, what camber are you running, Sano?
AlexN09 wrote: Just out of curiosity, what camber are you running, Sano?
Mr.HacKeR wrote: You don't want to know
Hence the reason I askedYoungCoupe wrote:That's awesome. To be honest, I was waiting for you to jump in because I figured you would have the most camber on this forum lol.
Thanks guys, always glad to help when I can. And yeah, a lot of people hate on the plates but the chicks love it so I don't careAlexN09 wrote:Hence the reason I askedYoungCoupe wrote:That's awesome. To be honest, I was waiting for you to jump in because I figured you would have the most camber on this forum lol.that's a sweet plate too.
20x10.5s and nope, not gramlights. I don't like their spokes.Weimy812 wrote:SanoSuke what size again you running and what wheels are they. They look like gramlights 57s Pro? Cuz i was looking into some and wasn't sure how they would look with the titanium finish.
No problem. Just ordered them myself. Had been looking for a while. I think some people also use 350z parts. I believe some of them are interchangeable.TIsaacs wrote:Thank you! All I could find was the camber toe bolts for the rear. I'm defiantly going to be ordering these!
SanSuke will have to let you know haha. Only thing I can guess is maybe you can adjust camber arm and toe bolt to achieve more camber.TIsaacs wrote:It says they only add a +/- 3 camber. How did he get up to 6?
If your wheels have a high positive offset close to OEM (+45) and is 18/19" depending on the tire size you won't need to adjust camber.TIsaacs wrote:Yeah I heard the g37 arms were interchangeable for the coupe as well. Is it a must to purchase this when lowering your car with coilovers? Just ordered BC coilovers last week. As you can see I'm new to this and this forum.
normmynorm wrote:If your wheels have a high positive offset close to OEM (+45) and is 18/19" depending on the tire size you won't need to adjust camber.TIsaacs wrote:Yeah I heard the g37 arms were interchangeable for the coupe as well. Is it a must to purchase this when lowering your car with coilovers? Just ordered BC coilovers last week. As you can see I'm new to this and this forum.
If you are running 19/20" wheels with more aggressive, lower positive offsets then camber will help you fit the wheel under the fender without rubbing, cause it's going to be poking. Also it will allow you to drop your car lower. SanSuke is on air suspension so he way down to the Earth haha.
I'm not completely sure how often tires need to be replaced in regards to camber. You could always stick to more of a OEM sized wheel and you'll be able to lower it as much as your coilovers or lowering springs allow you.TIsaacs wrote:Also, looking to slam my car as much possible. Just not sure if I want camber because I don't have a steady job and I'm not looking to purchase new tires every 3 months.
I purchased the rear toe camber bolt with my coilovers knowing I would need it. I just wasn't sure About the adjustable camber arm and if I would need it. I have a lifetime alignment and they told me they could adjust my toe and my camber cause I defiantly don't know how to.SanoSuKe wrote:The lower you are the more natural camber you will gain. If you don't want camber then you'll definitely need the arms. And again, it's not camber what wears your tires, it's the toe. So don't attempt to do this yourself because you'll never get the toe perfectly in spec.
Thank you for the link. And the rims I have now are Konigsnormmynorm wrote:I'm not completely sure how often tires need to be replaced in regards to camber. You could always stick to more of a OEM sized wheel and you'll be able to lower it as much as your coilovers or lowering springs allow you.TIsaacs wrote:Also, looking to slam my car as much possible. Just not sure if I want camber because I don't have a steady job and I'm not looking to purchase new tires every 3 months.
Hey at least you didn't spend money on them. 18x8 shouldn't give you any issues. Save up for some new ones haha.
Will be helpful
http://www.nicoclub.com/archives/wheel-tech.html
Give you a kind of comparison between stock and what you plan to put on
http://willtheyfit.com/
