Tires are wearing beautifully. It's going Monday to the dealer for some work, and I will have them check the alignment. BTW the negative camber seems to be only on the rear wheels.jettsetter4life22 wrote:yes you probably do have some negative camber its in infiniti the question you have to ask yourself is it so negative that it is wearing your tires. if it is your going to have to igure something out to bring camber positive. there usually isnt oem adjustment for camber or caster but a good alignment technician can ysually figure something out. on my 91 q45 i had to place shims in between the frame and the upper control arm mounts. let me know if you need any more help
There is a definite difference between -1.5° and -2.5° of static camber on the rear of my FGY33.Q45tech wrote:Most street tires are desisigned for less than 1.0 degrees of rolling camber.
Edit by Moderator: Unnecessary flame deleted. Stop the personal attacks, please.maxnix wrote:There is a definite difference between -1.5° and -2.5° of static camber on the rear of my FGY33.
Something is wrong if the front end is not wearing evenly side to side.Death by Mullet wrote:I am having the same issue on my 94 Q. I have got it alligned 3 times in the last 2 yeaars and the front end still wears WAY uneven.
This should be closest to OEM.maxnix wrote:Might want to read the FSM and report back your alignment specifications.
