You NEED to give us more info.Vidra wrote:I read about fixing it in the Installs but is this realisticly easy for me to do at home? If not, what are my other options? I realize I can buy an adjustable control arm which will solve my camber problem but how much easier is this than doing the Install? Thanks! Also --> Price is a major factor!
It might not be camber wear. Toe out can also cause wear on the inside of the tires. At any rate , you need to have the car aligned. You can lower it untill there is only about 3/4 of an inch gap from the tire to the fender, and still have it aligned to stock toe. However, if your car is this low, it is impossible for the stock camber settings to get rid of all the camber. Minimum camber will be around 2.5 degrees. You can order some rear upper control arms (rucas), which will give you a better range of camber adjustability. If you wan't to go lower than that, you will need some rear toe arms to correct your toe setting. Remember, everytiime you change the ride height of you car, or put on suspension peices, it needs to be aligned.Vidra wrote:car is lowered with coilovers. Car is 89 S13. I am experiencing negative camber wear. What can u suggest I buy as far as control arms go to fix this?
All I have is coilovers, rucas, and a good alignment. You don't even need ruca's, but you will have to deal with around -2.3 degrees camber. FYI, I have an inch gap between my tires and fenders. Im warning you though, you will want to go lower, as I do. I want to go another inch. For this, I will be getting close to the limit of the stock rear toe eccentric bolts, so I might need toe arms.amolao wrote:Naed240sxI dont mean to hijack this thread, but instead of starting a new one, allow me to ask you .... what are you running in your car when it comes to the rear of your suspension...???I've been using Eibachs and GR-2's for years, got a new set of Ksports and Im planning in lowering the car about the same height as yours...what will I need?? Just want to make sure, so I get the parts now and be ready for the coilover instal....Is Rucas all I need??
thanks
Toe links really aren't as nessicary if you have camber links. taking out the camber will fix the natural toe in.naed240sx wrote: Im warning you though, you will want to go lower, as I do. I want to go another inch. For this, I will be getting close to the limit of the stock rear toe eccentric bolts, so I might need toe arms.
I remember you saying this, but at an inch above my tires, running only -1.2 degrees rear camber, and 0 toe, I am very close to the limit of my rear toe eccentrics. Maybe the bushings are just really worn out? I would estimate that If I went lower, I would run out of toe adjustment.McRussellPants wrote:
It's false information. Camber adjustment will not fix toe.naed240sx wrote:I remember you saying this, but at an inch above my tires, running only -1.2 degrees rear camber, and 0 toe, I am very close to the limit of my rear toe eccentrics. Maybe the bushings are just really worn out? I would estimate that If I went lower, I would run out of toe adjustment.
