Negative Camber Question (pics)
300sx
Car: 1998 240sx
I was wondering if there is anything i can do to fix this besides raising it. I have Stance basic coilovers on my car and it is set to the max. Car is not really slammed. Even though I got 30k+ miles out of the front two tires I still want to reduce the inside tire wear.
Did i incorrectly install the coilovers? did i have to adjust the camber before bolting them on?
Gabes13
Car: rb20det s13
I wouldn't believe if you could get any more posi camber from those.
If you really want more posi camber, get yourself some s13 lower control arms.
hendogg8
Car: S13
The top hole on the bottom mounting bracket is elliptical. If you want less negative camber, make sure that you also pull the strut toward you when you tighten the bolt on that hole, so the bolt slides to the back end of the slotted hole. It won't make a huge difference, but it's still there for your adjustment.
Anyhow, have you gotten an alignment? Even if you're slammed, you should be able to get proper stock spec front camber with the range that's provided on those coilovers.
yokota180sx
Car: 1997 Stagea RS4, r34 front
yeah you can but your not gonna like it
fweld up your shock tower. move the shock outward...like literally remount it
yokota180sx
but i also have to adds14 or 14?you can also buy adjustable lower ontrol arms to fix it
300sx
Car: 1998 240sx
Thanks for the replies..
I've had the coilovers for i think 2 years and gotten the car aligned 3-4 times. i went to different shops and each time they can only get it close to stock specs like a +/- 1 off the stock spec
i just got new tires for the front so we'll see how many miles i can get out of them...hopefully 20k+
yokota..i've got an s14. maybe i'll invest in some LCA
Heres a pic
Modified by 300sx at 9:54 AM 6/29/2009
Skilz10179
Car: 98 240SX
30,000 miles on tires and you want more..............WTF!!!!!!!!!!
I'd be happy with 10,000 miles on a set of tires on any of my cars...
yokota180sx
im lucky if i get 5k on my cars
gumby74
If you are only off by that little, the cheapest route for you to take is to buy a pair of camber adjustment bolts.They generally run between $20 and $30 from pretty much any online retailer and may even be ordered through your local parts store. Use one bolt on each side replacing the stock upper bolt. This should give you an additional 1.5 to 2 full degrees of adjustment.
Dmafioso13
Car: 93 Fastback
you can mess with the factory eccenctric bolts in the rear. Normally a little negative camber in the front is good, more steering response. Id rather be able to hit a corner without understeering then squeeze a few extra thousand miles lol.
