Cal Learner »
https://forums.nicoclub.com/cal-learner-u123506.html
Fri Jan 02, 2009 3:09 am
Wife's 1990 Maxima GXE has recently developed a misfire/rough running condition after 133,000 miles. Until now, that 3.0L V6 has been a beautiful motor, and she's looking to get it back that way. Here's what's just been done within the past 30 days by our usually reliable indy:
1) all new injectors2) new coolant temp sensor3) new battery
Problem began last month with stumbling engine at all speeds. CEL on. Indy pulled code 51, injector circuit problem. Further diagnosis pointed to cyl 5 injector. While the intake manifold was off, we had him replace all six injectors with new OEM parts. For about one week, car ran fine. Then, one morning the car cranked long before starting and ran rough at all engine speeds, so back to the indy. This time, code 13, CTS. Replaced CTS with new OEM part (and new battery). No improvement. Further diagnosis led indy to suspect that now the new injector at cyl 3 was bad, altho there was no code set for bad injector. Indy replaced injector 3 with new one and the car appeared to my wife to run OK. Next morning, I tried it myself and it starts right up as it should and idled alright until the rpms dropped down to normal range, and then it was clear that there was intermittent misfire. I drove the car around the neighborhood. It runs alright on gentle acceleration and at neighborhood speeds (30 mph). But when I give it WOT, the engine seems to nearly stall out when the kickdown engages. Tach drops way down, and the engine just seems to stall until I let up on the accelerator, then the engine may either quit, or it may return to idle rpms. Each time I go WOT, the CEL comes on, but goes out again when I apply gentle accelerator pressure. That's where it stands today. Wife is going back to the indy today, but she could sure use some suggestions from knowledgeable Nissan DIYers. TIA
