needs help in regards to sr20det stock inj. can i go bigger
S13.5 ICHI-GO
Car: nissan 240sx 1990 s13.5
wassup guys i need help in regards to injectors the stock one in sr20det is it 370cc, and also can i put bigger injectors in it like 550cc cos i have SAFC 2,is there gonna be any problem in it, is there anybody here running bigger inj. in there stock motor and stock t25 turbo with the help of SAFC 2.and also what kind of injectors i could put on or i mean brand that i dont have to change the rails....thanks in advance....
[IMG][/IMG] http://www.cardomain.com/ride/2566397
Modified by S13.5 ICHI-GO at 10:12 AM 4/1/2007
bt2s14
Car: 96 s14 VG30E swap on the way
If you're going to roll around in that thing at least throw some ballin *** wheels on it.
HurryupandrunS13
Car: 1992 240 fastback
Got a buddy running 550s and a T4 on a stock block, it will work out fine. As far as the SAFC, if you know how to tune it you'll be good.
S13.5 ICHI-GO
thanks but i have a stock t25 , is it ok if ill put bigger injectors in it would be anybody knows about it, if is it ok...
S13.5 ICHI-GO
guys need help here more info pls.
sviellvoicae
Car: 1992 sil-40
i have 550's on mine with the stock 25 and i am still working on the correct mixture i would say dont do it ... so far hasnt done anything for me but givin me a headache!
S13.5 ICHI-GO
ok so do u have a safc to balance it or what did u use right now,and also is there anybody here what kind of injectors am going to get rathere than the stock injectors what brand and what size,thanks again
