NeedCAforS13 »
https://forums.nicoclub.com/needcafors13-u4234.html
Fri Apr 09, 2004 6:44 am
pulsar, silvia, and q45 all use the same exact chips with different part #'s on the side (same connectors)
VG and SR use the same connectors as each other if I'm remembering correctly, but different than CA's...
but if you find a junked car that you're pulling these off of, cut off afew inches of the harness and get the plugs on either side and wire it into yours. From what I've been told the colors either match up, or can be found online...
Sean
