need your opinion, help
slidecrave
Car: AE86, S13 CA coupe
ok so heres the deal my CA was running a bit rich so i adjusted that down and got it idling pretty damn good once its warmed up so it seemed all was good for a while but after not really driving it to much for a while...
well i went to drive it but it seemed to not wanna go and i would give it more gas and it would barely and slowly pick up speed. so i go around the parking lot for a little bit to make sure its all warmed up and then sit in a spot and it starts idling great again no dips or bogging. But then when driving again it does it again its slow to pick up speed through all gears and tends to bog out alot but still idles good..?
Could it be that its running too lean, also i know its leaking some oil i believe its coming from the valve cover havent really had much time to inspect. Also i removed the first coil and there is some oil at the tip of it and also the spark plug seems to also have some oil on the outside. Any ideas of what might be going on??? Also i will be doing a compression test later today when i get some time and checking all my spark plugs. LET ME KNOW WHAT YOU GUYS THINK MIGHT BE THE PROBLEM...?? I have to have it running to get home for a wedding, Thanks.
slidecrave
anyone..? could it be my timing belt?
