JF240 »
https://forums.nicoclub.com/jf240-u53718.html
Mon Feb 02, 2009 8:51 am
Hi,I need to have some opinion on guys that try some setup to know which will be the better the safer and also not too much expensive for nothing. So this is the part that I have:block sr20det black top740cc injectors tomei300zx maxintake greedybrand new garrett gt2876r .64 trimexternal wastegateand with all of the other think...blow off,, piping, fmic... fuel pump.. I only dont know which pistons I will need or which cams because it's sure that i make rebuild the block. I would like to install oem gtir pistons, because these are less expensive then wiseco or jc. And do I really need cams... I know it is better but which will be the best setup for the internal for you: pistons camshaft stock vs. aftermarket,
