shift_mikey »
https://forums.nicoclub.com/shift-mikey-u75645.html
Tue Sep 25, 2007 2:27 pm
Gasket sealer on exhaust? Stick to WAI installs! JK JK
First off, I'd say this is covered under warranty unless something clearly hit the bottom of the joint and caused it to bend. Water leaking is just condensation in the exhaust (#1 killer of all exhaust systems).
Second, there is more then likely some kind of high temperature gasket there which may have been installed incorrectly at the factory
Third, if you were to attempt the repair with some kinda of sealer, i'd suggest finding a high temp sealer that will withstand the temps of an exhaust system
