559_RA21 »
https://forums.nicoclub.com/559-ra21-u58904.html
Wed Mar 07, 2007 10:13 pm
well guys, i did compression test today and follow all the procedure i read on here to test the cylinders...cylinder 1 have 120, cylinder 2 have 130, cylinder 3 have 119, and cylinder 4 have 120....i also did a leakdown test too, cylinder 1, 2, &4 have no leakage but cylinder 3 have leak (as said on the gauge 20%) we put about 50 psi into the cylinders and put everything one to top dead center...this time i experience a little oil in cylinder 3 & 4....after we did the leakdown test...all the oil from cylinder 3 disappear so me and my friends were wondering that it's the piston ring...
my question is, i just bought the motor about a year ago and the seller told me that i have 8:5 compression...i was wondering if the compression have anything to do with the 120 compression all across the motor or are my rings going out...he said that they were je pistons 8:5 compression...
i'm planning to take off the head and take out the piston...should i just buy one piston or should i buy all four and rebuilt it again...is it just buying the new piston and put it by in or do i have to take it the block to the machine shop and have it clean...any suggestions? i would appreciate it very much...
