Need your help!!! ABS, SLIP, VDC light are on and Airbag light is blinking
pokladok
Car: G35 2003
Please help me i just bought G35 2003 sedan it was flooded. The lights are on, i mean ABS SLIP VDC and engine service soon, also airbag light is blinking after i took the seats out to clean the carpet.
Also did anybody here install original navigation into the G35??Thank You
s13sr20chris
there are many possibilities friend. could just be low on brake fluid or it could have toasted an important module like the airbag sensing and diag module. also it could be water causing a short. flood cars can be a real pain to diag. my advice:change all fluids asapremove entire interior to be cleaned or replacedinspect and dry all components and harnesses
thats the long drawn out way to possibly not fix anything.
better advice=tow to dealer and be ready for a serious estimate.
rydwhite
Car: 2003 Infiniti G35 Coupe
Sorry to hear about your problem.
It would be easier to take to dealer and have them run the diag. test and see exactly what's causing the problem. Should save you the headache of tearing the car apart and putting back together only to find that the problem is still present.
