sprocket »
https://forums.nicoclub.com/sprocket-u136001.html
Thu Jun 11, 2009 7:12 am
This car was owned by an enthusiast is my guess.
The front bumper lights have been replaced with clears.The tail lamps have been "split open" and the amber part replaced with clears.An Optima yellow has been installed.
Car looks clean. Manual is a plus, wish my old one was a manual.
At 100k .... things that you might want to look for:
Rear parking brake cable is routed close to the rear jack points at the sill (below the rear doors) and often get pinched. Cable is NOT cheap. Check both sides ... if it's nicked but not cut through the insulation, silicone dab to seal it will be fine. If you can see metal, the extent of corrosion is not known and the cable can seize up.
Rust shouldn't be an issue since you're not in the salt belt area. I've seen rust around wheel wells, doors, trunk lid (by the spoiler mounting holes), around jack points and at the lower radiator core center support. Of course, any car in the salt belt is going to rust.
Starter hesitation has been reported on the 4th gens. Or a starter whirr which sounds like a donkey whine for a split second after the car starts (presumably the solenoid delays disengaging).
Exhaust ; Look underneath to see if the rear muffler is in good shape. The flex pipe (called Y-pipe) at that age might also go.
Brakes ; rear calipers tend to need replacements because they seize up. Check if all 4 disc brakes are working. If the rotors look rusted compared to others, it's probably seized. Or take the wheels off and inspect at Midas or a local shop, or yourself. Check brake fluid color in the reservoir ... clean fluid is almost clear or slightly yellow, old dirty fluid is closer to black.
100k is a good time for a tune up. New platinum spark plugs (or copper with more frequent intervals), use only Bosch. New fuel filter (use an oversized one from a 300ZX).
I saw an aftermarket radio, I assume there are new speakers but if not, inspect the rear parcel shelf speakers. They go out with age.
Check to make sure the sunroof opens / closes / tilts properly in case a cable is snapped (rare) and to make sure it doesn't leak.
