ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Fri Mar 09, 2007 1:02 pm
if you use the redtop bracket with your S14 compressor, the AC compressor pulley will not line up. You have to swap out the compressor pulley.
I actually bought a set of CNC machine bracket that will perfecly line up my S14 compressor with the crank pulley. Contact Cody form FA. For the bracket and all the bolts and belt, I paid around 100 bucks which is very reasonable considering how much I sweat in that black leather interior during the summer time.
As for the wiring, you have a jump a wire at your F3 plug. So take the wire from AC switch at the F3 plug and jump it to AC Triple Pressure switch signal.
On the 96 F3 this is terminal 16 AC switch (Yellow/Black) to terminal 43 AC triple pressure switch(Black/Pink)
