Need write up for changing out a power steering rack (1995)
spedman
Car: 1995 nissan 240sx se
Hey guys, my power steering rack is completely messed up. Just ordered a brand new one and I need a write up with pics hopefully, or maybe a link to a free PDF service manual download. I have a 1995 nissan 240sx. I know I'm gonna need a lift, I just need to know how to take it out and put it in.
Thanks in advance!
180fan
Car: 89 fastback
you don't need a lift. but you will need a pickle fork if you plan on switching out your tie rod ends.
spedman
Do you have a link to the manual that came out of?
180fan
Car: 89 fastback
came out of the service manual that i've got at home.
spedman
Publisher/Title?
ricebike
2002 Quest
2005 Altima
see my sig!
180fan
Car: 89 fastback
it's a nissan factory service manual.
spedman
ricebike wrote:see my sig!
"Account has been suspended"
spedman
I have a FSM, but I can't seem to find that section, where is it located?
180fan
Car: 89 fastback
ST - steering
ricebike
2002 Quest
2005 Altima
spedman wrote:I have a FSM, but I can't seem to find that section, where is it located?
as far as your original post, I can do it w/ a floor jack/stands lifted up about 2 feet off the ground.
keep in mind to mark the outer tie rod end or measure them before taking that apart...
that way, you can reassemble it back to your car's specs so it'll drive str8 enuff to the shop for an alignment job.
any other pointers from fellow NICOnauts?
oh- u know to use red ATF & not the clear power steering fluid for this, right? just checkin'
180fan
Car: 89 fastback
ATF dexron III. Might want to take it to a car wash that can clean the underside before you tackle this one. It sucks having road grime fall into your eyes or your mouth as you're cussing about a busted knuckle...
spedman
lol, I'm far from alligned. I had taken it to the shop to get an allignment, that's when they told me they couldn't because the rack was junk. So rather then pay them $900, I figured I'd buy the part myself and do it. So, right now it's about alligned as it will get. However, I'll do it the old fashioned way after I Get it in, and use a tape measurer from tire to tire
Red ATF is dually noted, Thanks.
