i don't have a tach to compare the rpms to. the only way i would be able to adjust it is to set the tach at idle to around 900 rpms. so a friend of mine gave me his auto meter tach adapter.Carl H wrote:did tweaking the stock tach like i mentioned not work?
ok pin 7 it is yellow with blue tracer i never thought about "borrowing" one and i work at a auto parts store part time lol.Carl H wrote:ah, well the wire you are looking for is pin 7 on the ecu plug.yellow with a dark blue tracer.ive found 'borrowing' a tach from advance auto works, use it for 5 min then return it claiming it doesnt read on your car.
i was hoping it would ..........Sil240 wrote:The tach adapter makes the stock Tach work???
I have a Defi Tach and it did work just connecting it to the #7 pin on the ecu.
