ok, 92 SE hatch, stock with auto to manual swap, manual ecu, and brand new lower harness for manual from japan.
would just like to find out what these are to, and if they are connected properly
ok, i have these coming from the harness under the fuse/relay box
spliced into these
which then goes to here on the middle connector attached to the fuse box
ok next problem/concern
i have this plug not connected to anything. what is it to? should it be connected?
and this one, again not connected
then i have these wires!?!?!
also, the top and bottom connectors attached to the fuse box(there are three) do not have anything connected, only the middle one
if someone could help me sort this out, or point me towards a resource to help me sort it out any help would be awesome
