Need Wiring help, auto swap + ecu wiring.
ser2102
Car: 91 dead. 90 getting did
Ok heres the deal, ive pretty much gotten the whole harness done but i have a few questions. the little box that is above the ecu, which looks like a mini-me ECU; what is it, and what should i plug it into? do i leave it unplugged, or do i plug the usdm box into the sr20 harness? i noticed the wire colors dont match when plugged in so any advice would be great.
also for the auto swap, i know that on the passengerd side relay box, the top connector has 3 wires and they need to be "jumpered" exactly which wires am i doing? theres a white one, and two black ones. do i connect the white to one black wire or both? also the park switch next to the shifter, which colored wires did you guys connect. when i bought the car, it was already stripped and the shifter was gone. i saw at a junk yard which ones to connect, but on mine they were different colors. probably because the sohc auto was different than my dohc . any help would be appreciated
(p.s. i was ready to start up the car for the first time almost when i noticed the exhaust manifold outlet had come loose and the whole turbo was shifting back and forth. arrrg)
karmakaze
Car: 98 240sx SE
ser2102
so does anyone know what that mini ecu looking thing does and should i plug the usdm one into the sr20 harness or just leave it unplugged?
