Need Wiring for MSD SCI
HolyShiznit
Car: Working on my car
Like the title says I need wiring diagram for the MSD SCI box on the KA, also installation of the MSD blaster coil 2, I don't need the basic diagram that MSD gives you I need an depth like which colors go to what wires on the distributor and where the tach hooks up, etc etc. Thanks guys!
Structure240sx
check out your fsm to see which wires are what. then match them up with the msd. should need to go into the coil + wire, the swtich power, a direct wire to the battery like my 7a-l and a ground or two
the tach im pretty sure is off the coil + wire
