Holidazed wrote:02pathy: unfortunatly none of the pathfinders there have a power antenna, those didnt get added until 2001.
Lars: I dont know where the EVAP purge control value is, but here is a pic of the throttle body. is it on there?
Qxxx4: I have some of the parts you need but not all.Rear passenger side cargo cover: YES, here's a pictureRear tail/wing: YES, 3 of them to chose from, heres a pictureheadlight corners for 97-00 qx4: there are only pathfinders but he has a corner light for a pathfinder, will this fit your qx4? from a 98 or 99. heres a pic
slickroger: -The center console that clip that holds the center armrest: YES, which clip do you need? the upper one or lower? also will the clip from a 98 or 99 fit the 2001? heres pics- The Rear Cargo light cover: YES, heres a pic
Any chance you still have the rubber intake elbow from a 3.3L in the first picture? I could use a replacement. Also, I'm hoping one of those Pathy's has the the jack handle with the square hole in the middle of the shaft (not the long t-rod) Would you let me know?
Thx,
Al
